Motorola V557 Camera Replacement
  1. Motorola V557 Camera Replacement, Battery: step 1, image 1 of 3 Motorola V557 Camera Replacement, Battery: step 1, image 2 of 3 Motorola V557 Camera Replacement, Battery: step 1, image 3 of 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Camera Replacement: step 2, image 1 of 2 Motorola V557 Camera Replacement: step 2, image 2 of 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Camera Replacement, Faceplate: step 3, image 1 of 3 Motorola V557 Camera Replacement, Faceplate: step 3, image 2 of 3 Motorola V557 Camera Replacement, Faceplate: step 3, image 3 of 3
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  4. Motorola V557 Camera Replacement: step 4, image 1 of 2 Motorola V557 Camera Replacement: step 4, image 2 of 2
    • Remove the four 3.8 mm T-6 Torx screws.
  5. Motorola V557 Camera Replacement: step 5, image 1 of 2 Motorola V557 Camera Replacement: step 5, image 2 of 2
    • Separate the cover from the edges using a plastic opening tool.
  6. Motorola V557 Camera Replacement: step 6, image 1 of 2 Motorola V557 Camera Replacement: step 6, image 2 of 2
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  7. Motorola V557 Camera Replacement, Camera: step 7, image 1 of 1
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  8. Motorola V557 Camera Replacement: step 8, image 1 of 2 Motorola V557 Camera Replacement: step 8, image 2 of 2
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  9. Motorola V557 Camera Replacement: step 9, image 1 of 2 Motorola V557 Camera Replacement: step 9, image 2 of 2
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  10. Motorola V557 Camera Replacement: step 10, image 1 of 2 Motorola V557 Camera Replacement: step 10, image 2 of 2
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  11. Motorola V557 Camera Replacement: step 11, image 1 of 3 Motorola V557 Camera Replacement: step 11, image 2 of 3 Motorola V557 Camera Replacement: step 11, image 3 of 3
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  12. Motorola V557 Camera Replacement: step 12, image 1 of 2 Motorola V557 Camera Replacement: step 12, image 2 of 2
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
2 other people completed this guide.
Matthew Sanders
43 Reputation
2 Guides authored
Cal Poly, Team 7-50, Amido Fall 2010 Member of Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,785
