Motorola V557 Faceplate Replacement
  1. Motorola V557 Faceplate Replacement, Faceplate: step 1, image 1 of 3 Motorola V557 Faceplate Replacement, Faceplate: step 1, image 2 of 3 Motorola V557 Faceplate Replacement, Faceplate: step 1, image 3 of 3
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  2. Motorola V557 Faceplate Replacement: step 2, image 1 of 2 Motorola V557 Faceplate Replacement: step 2, image 2 of 2
    • Remove the four 3.8 mm T-6 Torx screws.
  3. Motorola V557 Faceplate Replacement: step 3, image 1 of 2 Motorola V557 Faceplate Replacement: step 3, image 2 of 2
    • Separate the cover from the edges using a plastic opening tool.
  4. Motorola V557 Faceplate Replacement: step 4, image 1 of 2 Motorola V557 Faceplate Replacement: step 4, image 2 of 2
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
Blair Frandeen
19 Reputation
4 Guides authored
Cal Poly, Team 7-50, Amido Fall 2010 Member of Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,976
