Motorola V557 Keypad Replacement
  1. Motorola V557 Keypad Replacement, Battery: step 1, image 1 of 3 Motorola V557 Keypad Replacement, Battery: step 1, image 2 of 3 Motorola V557 Keypad Replacement, Battery: step 1, image 3 of 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Keypad Replacement: step 2, image 1 of 2 Motorola V557 Keypad Replacement: step 2, image 2 of 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Keypad Replacement, SIM Card: step 3, image 1 of 3 Motorola V557 Keypad Replacement, SIM Card: step 3, image 2 of 3 Motorola V557 Keypad Replacement, SIM Card: step 3, image 3 of 3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Keypad Replacement, Antenna: step 4, image 1 of 2 Motorola V557 Keypad Replacement, Antenna: step 4, image 2 of 2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Keypad Replacement, Rear Casing: step 5, image 1 of 3 Motorola V557 Keypad Replacement, Rear Casing: step 5, image 2 of 3 Motorola V557 Keypad Replacement, Rear Casing: step 5, image 3 of 3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Keypad Replacement: step 6, image 1 of 3 Motorola V557 Keypad Replacement: step 6, image 2 of 3 Motorola V557 Keypad Replacement: step 6, image 3 of 3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Keypad Replacement: step 7, image 1 of 3 Motorola V557 Keypad Replacement: step 7, image 2 of 3 Motorola V557 Keypad Replacement: step 7, image 3 of 3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
  8. Motorola V557 Keypad Replacement, Motherboard: step 8, image 1 of 3 Motorola V557 Keypad Replacement, Motherboard: step 8, image 2 of 3 Motorola V557 Keypad Replacement, Motherboard: step 8, image 3 of 3
    • Separate the front ribbon cable from the board with a plastic opening tool.
  9. Motorola V557 Keypad Replacement: step 9, image 1 of 3 Motorola V557 Keypad Replacement: step 9, image 2 of 3 Motorola V557 Keypad Replacement: step 9, image 3 of 3
    • Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard.
    • Lift out the motherboard only after all cables have been disconnected. Try to touch it only from the sides.
  10. Motorola V557 Keypad Replacement, Keypad: step 10, image 1 of 3 Motorola V557 Keypad Replacement, Keypad: step 10, image 2 of 3 Motorola V557 Keypad Replacement, Keypad: step 10, image 3 of 3
    • With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom.
Chad Brantley
32 Reputation
2 Guides authored
Cal Poly, Team 7-50, Amido Fall 2010 Member of Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,120
