Motorola V710 Keyboard Replacement
  1. Motorola V710 Keyboard Replacement, Battery: step 1, image 1 of 3 Motorola V710 Keyboard Replacement, Battery: step 1, image 2 of 3 Motorola V710 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Keyboard Replacement: step 2, image 1 of 3 Motorola V710 Keyboard Replacement: step 2, image 2 of 3 Motorola V710 Keyboard Replacement: step 2, image 3 of 3
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Keyboard Replacement, Keypad: step 3, image 1 of 1
    • Unscrew the antenna with a clockwise motion and pull to remove the antenna.
  4. Motorola V710 Keyboard Replacement: step 4, image 1 of 2 Motorola V710 Keyboard Replacement: step 4, image 2 of 2
    • Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver.
  5. Motorola V710 Keyboard Replacement: step 5, image 1 of 2 Motorola V710 Keyboard Replacement: step 5, image 2 of 2
    • Use the spudger to remove the bottom plate.
  6. Motorola V710 Keyboard Replacement: step 6, image 1 of 2 Motorola V710 Keyboard Replacement: step 6, image 2 of 2
    • Unscrew the bottom two screws with the T6 screwdriver.
  7. Motorola V710 Keyboard Replacement: step 7, image 1 of 2 Motorola V710 Keyboard Replacement: step 7, image 2 of 2
    • Use the spudger to remove the keyboard plate.
  8. Motorola V710 Keyboard Replacement: step 8, image 1 of 1
    • Use your fingers to push out the keyboard.
Finish Line
Karl Sanders
8 Reputation
7 Guides authored
Cal Poly, Team 8-49, Regan Winter 2010 Member of Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 2,041
