Motorola W385 Front Casing Replacement
  1. Motorola W385 Front Casing Replacement, Battery: step 1, image 1 of 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Front Casing Replacement: step 2, image 1 of 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Front Casing Replacement, Front Casing: step 3, image 1 of 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Front Casing Replacement: step 4, image 1 of 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Front Casing Replacement: step 5, image 1 of 2 Motorola W385 Front Casing Replacement: step 5, image 2 of 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Front Casing Replacement: step 6, image 1 of 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
Austin Hobbs
69 Reputation
3 Guides authored
Cal Poly, Team 8-50, Regan Winter 2010 Member of Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,053
