Motorola XOOM 2 Media Edition Battery Replacement
  1. Motorola XOOM 2 Media Edition Battery Replacement, Battery: step 1, image 1 of 2 Motorola XOOM 2 Media Edition Battery Replacement, Battery: step 1, image 2 of 2
    • Power off your tablet before beginning disassembly.
    • Remove six 2.74mm Torx #3 screws from the back panel of the device with a Torx T3 screwdriver.
  2. Motorola XOOM 2 Media Edition Battery Replacement: step 2, image 1 of 2 Motorola XOOM 2 Media Edition Battery Replacement: step 2, image 2 of 2
    • There is adhesive attached to the underside of the back panel. Gradually lift panel to avoid bending it out of shape.
    • Pry off the back panel with a plastic opening tool.
  3. Motorola XOOM 2 Media Edition Battery Replacement: step 3, image 1 of 2 Motorola XOOM 2 Media Edition Battery Replacement: step 3, image 2 of 2
    • These screws are tight and prone to becoming stripped.
    • The battery cables are likely to snap when removing the screws.
    • Remove two 2.38mm Torx #5 screws from battery cables with Torx T5 screwdriver.
  4. Motorola XOOM 2 Media Edition Battery Replacement: step 4, image 1 of 3 Motorola XOOM 2 Media Edition Battery Replacement: step 4, image 2 of 3 Motorola XOOM 2 Media Edition Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Pull up the battery cables and battery chip with tweezers.
  5. Motorola XOOM 2 Media Edition Battery Replacement: step 5, image 1 of 2 Motorola XOOM 2 Media Edition Battery Replacement: step 5, image 2 of 2
    • Pry the battery out of the device with the plastic opening tool.
    • Some force is needed to lift the battery up because of the adhesive attached to the backside of the battery.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,074
