Motorola XOOM 2 Media Edition Touch Screen Replacement
  1. Motorola XOOM 2 Media Edition Touch Screen Replacement, Motorola XOOM 2 Media Edition Disassembly: step 1, image 1 of 2 Motorola XOOM 2 Media Edition Touch Screen Replacement, Motorola XOOM 2 Media Edition Disassembly: step 1, image 2 of 2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Touch Screen Replacement: step 2, image 1 of 2 Motorola XOOM 2 Media Edition Touch Screen Replacement: step 2, image 2 of 2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Touch Screen Replacement: step 3, image 1 of 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: step 3, image 2 of 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: step 3, image 3 of 3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Touch Screen Replacement, Touch Screen: step 4, image 1 of 2 Motorola XOOM 2 Media Edition Touch Screen Replacement, Touch Screen: step 4, image 2 of 2
    • Remove thirteen 2.55mm Torx #4 screws with Torx T4 screwdriver.
  5. Motorola XOOM 2 Media Edition Touch Screen Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to pull up the white rubber cover.
  6. Motorola XOOM 2 Media Edition Touch Screen Replacement: step 6, image 1 of 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: step 6, image 2 of 3 Motorola XOOM 2 Media Edition Touch Screen Replacement: step 6, image 3 of 3
    • Use the tweezers to pull up the small chip from its receiver.
    • Use the tweezers to pull up the larger chip from its receiver.
    • There is adhesive attached to the back of the larger chip on the touchscreen controller strip.
    • Use the tweezers to pull up one end of the small piece of tape that is holding the touchscreen controller.
  7. Motorola XOOM 2 Media Edition Touch Screen Replacement: step 7, image 1 of 2 Motorola XOOM 2 Media Edition Touch Screen Replacement: step 7, image 2 of 2
    • Use the tweezers to pull up and release the thin handle that is attached to the LCD connector.
    • Use the tweezers to pull out the LCD connector from its receptor.
  8. Motorola XOOM 2 Media Edition Touch Screen Replacement: step 8, image 1 of 2 Motorola XOOM 2 Media Edition Touch Screen Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to gradually separate the screen from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 657
