Motorola Xoom Wifi Back-Facing Camera Replacement
  1. Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: step 1, image 1 of 2 Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: step 1, image 2 of 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Back-Facing Camera Replacement: step 2, image 1 of 2 Motorola Xoom Wifi Back-Facing Camera Replacement: step 2, image 2 of 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Back-Facing Camera Replacement: step 3, image 1 of 3 Motorola Xoom Wifi Back-Facing Camera Replacement: step 3, image 2 of 3 Motorola Xoom Wifi Back-Facing Camera Replacement: step 3, image 3 of 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: step 4, image 1 of 2 Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: step 4, image 2 of 2
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  5. Motorola Xoom Wifi Back-Facing Camera Replacement: step 5, image 1 of 2 Motorola Xoom Wifi Back-Facing Camera Replacement: step 5, image 2 of 2
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
2 other people completed this guide.
Andrew Mercier
532 Reputation
3 Guides authored
Cal Poly, Team 3-39, Maness Spring 2014 Member of Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 392
