Motorola Xoom Wifi Battery Replacement
  1. Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: step 1, image 1 of 2 Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: step 1, image 2 of 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Battery Replacement: step 2, image 1 of 2 Motorola Xoom Wifi Battery Replacement: step 2, image 2 of 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Battery Replacement: step 3, image 1 of 3 Motorola Xoom Wifi Battery Replacement: step 3, image 2 of 3 Motorola Xoom Wifi Battery Replacement: step 3, image 3 of 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Battery Replacement, Battery: step 4, image 1 of 2 Motorola Xoom Wifi Battery Replacement, Battery: step 4, image 2 of 2
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Battery Replacement: step 5, image 1 of 2 Motorola Xoom Wifi Battery Replacement: step 5, image 2 of 2
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
6 other people completed this guide.
Andrew Mercier
532 Reputation
3 Guides authored
Cal Poly, Team 3-39, Maness Spring 2014 Member of Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Members
16 Guides authored
One Comment
does anyone know what the function of the black and red wires are? my connector came off the motherboard.
Duli - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 4,603
