Motorola i450 Boost Mobile Antenna Replacement
  1. Motorola i450 Boost Mobile Antenna Replacement, Antenna: step 1, image 1 of 3 Motorola i450 Boost Mobile Antenna Replacement, Antenna: step 1, image 2 of 3 Motorola i450 Boost Mobile Antenna Replacement, Antenna: step 1, image 3 of 3
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. Motorola i450 Boost Mobile Antenna Replacement: step 2, image 1 of 3 Motorola i450 Boost Mobile Antenna Replacement: step 2, image 2 of 3 Motorola i450 Boost Mobile Antenna Replacement: step 2, image 3 of 3
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
Garrison Stevens
1 Reputation
6 Guides authored
Clemson, Team 15-2, Benson Fall 2012 Member of Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 410
