Motorola i450 Boost Mobile Circuit Board Replacement
  1. Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: step 1, image 1 of 3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: step 1, image 2 of 3 Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: step 1, image 3 of 3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Circuit Board Replacement, Battery: step 2, image 1 of 3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: step 2, image 2 of 3 Motorola i450 Boost Mobile Circuit Board Replacement, Battery: step 2, image 3 of 3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: step 3, image 1 of 2 Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: step 3, image 2 of 2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Circuit Board Replacement: step 4, image 1 of 3 Motorola i450 Boost Mobile Circuit Board Replacement: step 4, image 2 of 3 Motorola i450 Boost Mobile Circuit Board Replacement: step 4, image 3 of 3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Circuit Board Replacement, Circuit Board: step 5, image 1 of 1
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Circuit Board Replacement: step 6, image 1 of 1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Circuit Board Replacement: step 7, image 1 of 3 Motorola i450 Boost Mobile Circuit Board Replacement: step 7, image 2 of 3 Motorola i450 Boost Mobile Circuit Board Replacement: step 7, image 3 of 3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
Amber King
8 Reputation
2 Guides authored
Clemson, Team 15-2, Benson Fall 2012 Member of Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 439
