Motorola i560 Microphone Replacement
  1. Motorola i560 Microphone Replacement, Battery: step 1, image 1 of 1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Microphone Replacement: step 2, image 1 of 1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Microphone Replacement, Side Volume Button: step 3, image 1 of 1
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Microphone Replacement: step 4, image 1 of 1
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Microphone Replacement: step 5, image 1 of 2 Motorola i560 Microphone Replacement: step 5, image 2 of 2
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Microphone Replacement: step 6, image 1 of 2 Motorola i560 Microphone Replacement: step 6, image 2 of 2
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Microphone Replacement: step 7, image 1 of 3 Motorola i560 Microphone Replacement: step 7, image 2 of 3 Motorola i560 Microphone Replacement: step 7, image 3 of 3
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Microphone Replacement, Metal Support Plate: step 8, image 1 of 3 Motorola i560 Microphone Replacement, Metal Support Plate: step 8, image 2 of 3 Motorola i560 Microphone Replacement, Metal Support Plate: step 8, image 3 of 3
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
  9. Motorola i560 Microphone Replacement, Microphone: step 9, image 1 of 3 Motorola i560 Microphone Replacement, Microphone: step 9, image 2 of 3 Motorola i560 Microphone Replacement, Microphone: step 9, image 3 of 3
    • Slightly bend the phone frame to expose microphone protrusion.
    • Gently remove microphone using your fingers.
  10. Motorola i560 Microphone Replacement: step 10, image 1 of 1
    • Once the microphone has been removed, remove the connecting piece
Haley S
10 Reputation
4 Guides authored
Clemson, Team 13-6, Benson Spring 2013 Member of Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 264
