Motorola i560 Screen Replacement
  1. Motorola i560 Screen Replacement, Battery: step 1, image 1 of 1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Screen Replacement: step 2, image 1 of 1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Screen Replacement, Motherboard: step 3, image 1 of 1
    • Pull the antenna up to reveal two of the six screws.
  4. Motorola i560 Screen Replacement: step 4, image 1 of 1
    • Unscrew all six screws on the back side of the phone using a T-6 bit.
  5. Motorola i560 Screen Replacement: step 5, image 1 of 2 Motorola i560 Screen Replacement: step 5, image 2 of 2
    • Gently separate the front and back sides of the phone, as shown in the picture.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Screen Replacement: step 6, image 1 of 2 Motorola i560 Screen Replacement: step 6, image 2 of 2
    • Detach the first ribbon cable by unplugging it from the motherboard.
  7. Motorola i560 Screen Replacement: step 7, image 1 of 2 Motorola i560 Screen Replacement: step 7, image 2 of 2
    • Detach the speaker ribbon cable from the motherboard.
  8. Motorola i560 Screen Replacement: step 8, image 1 of 1
    • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
  9. Motorola i560 Screen Replacement, Keypad: step 9, image 1 of 1
    • Push lightly from the front of the keypad to remove it.
  10. Motorola i560 Screen Replacement, Screen: step 10, image 1 of 2 Motorola i560 Screen Replacement, Screen: step 10, image 2 of 2
    • By applying force, "pop" the screen out of the connecting hinge frame of the phone.
  11. Motorola i560 Screen Replacement: step 11, image 1 of 2 Motorola i560 Screen Replacement: step 11, image 2 of 2
    • Carefully slide the speaker ribbon cable through the slot in the front frame of the phone.
  12. Motorola i560 Screen Replacement: step 12, image 1 of 1
    • After sliding the ribbon cable through the front frame of the phone, the separated screen and phone frame will appear as shown.
Ariel
19 Reputation
4 Guides authored
Clemson, Team 13-6, Benson Spring 2013 Member of Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 257
