Motorola i90c Antenna Replacement
  1. Motorola i90c Antenna Replacement, Battery: step 1, image 1 of 3 Motorola i90c Antenna Replacement, Battery: step 1, image 2 of 3 Motorola i90c Antenna Replacement, Battery: step 1, image 3 of 3
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Motorola i90c Antenna Replacement: step 2, image 1 of 3 Motorola i90c Antenna Replacement: step 2, image 2 of 3 Motorola i90c Antenna Replacement: step 2, image 3 of 3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Motorola i90c Antenna Replacement, Antenna: step 3, image 1 of 2 Motorola i90c Antenna Replacement, Antenna: step 3, image 2 of 2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
Jorge
4 Reputation
4 Guides authored
Cal Poly, Team 29-61, Johann Spring 2010 Member of Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,774
