Moultrie I45 GameSpy Buttons Replacement
  1. Moultrie I45 GameSpy Buttons Replacement, Casing: step 1, image 1 of 1
    • Using a Philips head screwdriver, remove the eight 6mm screws located at the bottom of the device.
  2. Moultrie I45 GameSpy Buttons Replacement: step 2, image 1 of 1
    • Remove the butterfly nut from the lid arm.
  3. Moultrie I45 GameSpy Buttons Replacement: step 3, image 1 of 1
    • Remove the lid-covering.
  4. Moultrie I45 GameSpy Buttons Replacement: step 4, image 1 of 1
    • Using a Phillips head screwdriver, remove the six 4mm screws from the face of the camera.
  5. Moultrie I45 GameSpy Buttons Replacement: step 5, image 1 of 1
    • Gently separate the two halves of the case.
    • The two halves are connected by a wire. Pulling too roughly can damage the wires and cause the camera to stop functioning.
  6. Moultrie I45 GameSpy Buttons Replacement, Buttons: step 6, image 1 of 1
    • Using a Phillips head screwdriver, remove the twelve 3mm screws from the circuit board.
  7. Moultrie I45 GameSpy Buttons Replacement: step 7, image 1 of 1
    • Gently remove the circuit board from the face of the camera.
  8. Moultrie I45 GameSpy Buttons Replacement: step 8, image 1 of 1
    • Remove the buttons.
Sean Hill
485 Reputation
4 Guides authored
UW Tacoma, Team 3-7, Rose Winter 2015 Member of UW Tacoma, Team 3-7, Rose Winter 2015
UWT-ROSE-W15S3G7
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 438
