Mountain Bike Brake Lever Replacement
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: step 1, image 1 of 2 Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: step 1, image 2 of 2
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: step 2, image 1 of 2 Mountain Bike Brake Lever Replacement: step 2, image 2 of 2
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: step 3, image 1 of 1
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: step 4, image 1 of 2 Mountain Bike Brake Lever Replacement: step 4, image 2 of 2
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: step 5, image 1 of 1
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: step 6, image 1 of 3 Mountain Bike Brake Lever Replacement: step 6, image 2 of 3 Mountain Bike Brake Lever Replacement: step 6, image 3 of 3
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: step 7, image 1 of 3 Mountain Bike Brake Lever Replacement: step 7, image 2 of 3 Mountain Bike Brake Lever Replacement: step 7, image 3 of 3
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
0 Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 122
All Time: 3,735
