Mpow MPBH063 Battery Replacement
  1. Mpow MPBH063 Battery Replacement, Battery: step 1, image 1 of 3 Mpow MPBH063 Battery Replacement, Battery: step 1, image 2 of 3 Mpow MPBH063 Battery Replacement, Battery: step 1, image 3 of 3
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Battery Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Battery Replacement: step 3, image 1 of 1
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
  4. Mpow MPBH063 Battery Replacement: step 4, image 1 of 1
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
Lianna Cook
248 Reputation
2 Guides authored
2 Comments
Where can I find a replacement battery for this speaker?
Sean DuBois - Reply
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - Reply
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 24
All Time: 4,333
