Mpow MPBH063 Daughterboard Replacement
  1. Mpow MPBH063 Daughterboard Replacement, Daughterboard: step 1, image 1 of 1
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Daughterboard Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Daughterboard Replacement: step 3, image 1 of 1
    • Unplug the wire connected to the daughterboard.
  4. Mpow MPBH063 Daughterboard Replacement: step 4, image 1 of 1
    • Remove the silver 10 mm screw from the center of the daughterboard.
  5. Mpow MPBH063 Daughterboard Replacement: step 5, image 1 of 2 Mpow MPBH063 Daughterboard Replacement: step 5, image 2 of 2
    • Remove the daughterboard by carefully lifting the daughterboard out of the speaker with the metal spudger.
    • Use iFixit adhesive remover as directed
    • Before you remove the daughterboard, cut around the edges using the tech knife, and remove the adhesive securing the daughterboard to the speaker.
Jazely Barrera
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 163
