Mr. Coffee BVMC-SJX33GT O-Rings Replacement
  1. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Base: step 1, image 1 of 1
    • Turn your coffee maker over so that the base is facing up.
  2. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 2, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 2, image 2 of 2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
  3. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, security screws: step 3, image 1 of 1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
  4. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 4, image 1 of 1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
  5. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: step 5, image 1 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: step 5, image 2 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: step 5, image 3 of 3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
  6. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 6, image 1 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 6, image 2 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 6, image 3 of 3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
  7. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 7, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 7, image 2 of 2
    • Slide metal clamps off hoses.
  8. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 8, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 8, image 2 of 2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
  9. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 9, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 9, image 2 of 2
    • Grip the hoses and pull them straight up and out.
  10. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: step 10, image 1 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: step 10, image 2 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: step 10, image 3 of 3
    • Locate the two 17mm screws securing the bracing bar.
    • Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
  11. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 11, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 11, image 2 of 2
    • Using a finger to keep the heating plate in place, grip the metal tubing and gently pull it away from the plate.
    • Set the metal tubing aside.
  12. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 12, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 12, image 2 of 2
    • Push the heating plate up from below and remove.
  13. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: step 13, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: step 13, image 2 of 2
    • Locate the five 11.5mm screws securing the plastic ring to the coffee maker.
    • Unscrew the screws using a #2 Phillip's head screwdriver.
  14. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 14, image 1 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 14, image 2 of 3 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 14, image 3 of 3
    • Using a plastic opening tool, pry the first o-ring out of the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thicker than the second.
  15. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 15, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 15, image 2 of 2
    • Gripping the plastic ring, pull it free from the coffee maker.
    • Flip the plastic ring over.
  16. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 16, image 1 of 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: step 16, image 2 of 2
    • Using your fingers, pry the other o-ring free from the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thinner than the first.
Mackenzie Aiken
1,473 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,433
