Mr. Coffee DW13 Base Removal
  1. Mr. Coffee DW13 Base Removal, Base: step 1, image 1 of 2 Mr. Coffee DW13 Base Removal, Base: step 1, image 2 of 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Base Removal: step 2, image 1 of 2 Mr. Coffee DW13 Base Removal: step 2, image 2 of 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Base Removal: step 3, image 1 of 1
    • Gently lift the base cover to expose the inside of the coffee machine.
Tess Bradley
373 Reputation
3 Guides authored
Cal Poly, Team 10-31, Maness Winter 2014 Member of Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 30
All Time: 3,179
