Introduction
To complete this repair you will need pilers, a Philips head screwdriver, and a flathead screw driver. During this repair you will remove the base of the coffee machine, loosen the support bar, before finally removing the heating plate and prying out the O-ring.
Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
Use a 2.5 mm Flathead Screwdriver to pry out the O-ring.
3 other people completed this guide.
