Mt. Fury Roadmaster Brake Pad Replacement
  1. Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: step 1, image 1 of 2 Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: step 1, image 2 of 2
    • Locate and remove the dome nut with a 10mm open-end wrench.
  2. Mt. Fury Roadmaster Brake Pad Replacement: step 2, image 1 of 1
    • Inspect brake pad for wear.
  3. Mt. Fury Roadmaster Brake Pad Replacement: step 3, image 1 of 1
    • Dome nut (left), lock washer (middle), and brake pad (right).
    • Be sure to save the dome nut and lock washer just in case the replacement brake shoe does not include them.
    • When installing the new brake shoe, make sure it is properly aligned so it is in full contact with the edge of the rim.
To install your new brake shoes, follow these instructions in reverse order.
Monty Dodge Jr
669 Reputation
2 Guides authored
Cal Poly, Team 1-40, Maness Winter 2014 Member of Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 2,069
