Munchkin Mozart Magic Cube Face plate Replacement
  1. Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: step 1, image 1 of 2 Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: step 1, image 2 of 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Face plate  Replacement: step 2, image 1 of 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Face plate  Replacement: step 3, image 1 of 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Face plate  Replacement: step 4, image 1 of 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Face plate  Replacement: step 5, image 1 of 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Face plate  Replacement: step 6, image 1 of 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Face plate  Replacement: step 7, image 1 of 1
    • Remove the rubber corners by simply pulling them off.
Ibrahim Aldairem
335 Reputation
2 Guides authored
USF Tampa, Team 1-4, Sullivan Fall 2015 Member of USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,184
