Munchkin Mozart Magic Cube Speaker Replacement
  1. Munchkin Mozart Magic Cube Speaker Replacement, Face plate: step 1, image 1 of 2 Munchkin Mozart Magic Cube Speaker Replacement, Face plate: step 1, image 2 of 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Speaker Replacement: step 2, image 1 of 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Speaker Replacement: step 3, image 1 of 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Speaker Replacement: step 4, image 1 of 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Speaker Replacement: step 5, image 1 of 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Speaker Replacement: step 6, image 1 of 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Speaker Replacement: step 7, image 1 of 1
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Speaker Replacement, Frame Removal: step 8, image 1 of 1
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
  9. Munchkin Mozart Magic Cube Speaker Replacement, Speaker: step 9, image 1 of 1
    • Remove four 6 mm Phillips #2 screws that hold down the speaker to its plastic frame.
  10. Munchkin Mozart Magic Cube Speaker Replacement: step 10, image 1 of 1
    • Remove two 6 mm Phillips #2 screws holding down the main motherboard to plastic frame.
  11. Munchkin Mozart Magic Cube Speaker Replacement: step 11, image 1 of 1
    • Gently remove speaker and motherboard from plastic frame.
  12. Munchkin Mozart Magic Cube Speaker Replacement: step 12, image 1 of 1
  13. Munchkin Mozart Magic Cube Speaker Replacement: step 13, image 1 of 1
    • Desolder speaker cable connections from the motherboard.
    • If you're unsure which metal connector to unsolder note that SPK is written next to the metal spot,
Paula Campos
126 Reputation
1 Guide authored
USF Tampa, Team 1-4, Sullivan Fall 2015 Member of USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,025
