Munchkinz Battery Replacement
  1. Munchkinz Battery Replacement, Opening Device: step 1, image 1 of 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Battery Replacement, Pry Device Apart: step 2, image 1 of 2 Munchkinz Battery Replacement, Pry Device Apart: step 2, image 2 of 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Battery Replacement, Separated Device: step 3, image 1 of 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Battery Replacement, Removing battery: step 4, image 1 of 3 Munchkinz Battery Replacement, Removing battery: step 4, image 2 of 3 Munchkinz Battery Replacement, Removing battery: step 4, image 3 of 3
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  5. Munchkinz Battery Replacement, Remove battery completely: step 5, image 1 of 1
    • Use the Soldering Iron to disconnect the each cable.
Hee Jin Cho
113 Reputation
1 Guide authored
UW Tacoma, Team 3-6, Rose Winter 2015 Member of UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 585
