MusicAngel JH-MD04E2 wired speakers Disassembly
  1. MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: step 1, image 1 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: step 1, image 2 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: step 1, image 3 of 3
    • Bottom side has 4 5.95mm tapping Phillips #1 screws, under a rubber cover.
    • Under the label, there are two more Phillips #1 screws 9.15mm tapping screws.
  2. MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: step 2, image 1 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: step 2, image 2 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: step 2, image 3 of 3
    • Use a very thin metal prying tool and slide it in between the metal looking grill and the speaker body. Carefully pry it out (no glue is used) all the way around.
    • Repeat on both speaker sides.
  3. MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: step 3, image 1 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: step 3, image 2 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: step 3, image 3 of 3
    • Use a spudger to pry the battery that is glued to the top, from the body. Note: This is pretty strong adhesive.
    • Tilt the speaker grill / element a little, to slide it through the body.
  4. MusicAngel JH-MD04E2 wired speakers Disassembly, Information: step 4, image 1 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: step 4, image 2 of 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: step 4, image 3 of 3
    • As you can see, there are no connectors used. All connections are soldered directly to the board.
    • No information can be found on the battery, either side.
    • The speaker elements are 45mm, 3W and 4Ω
  5. MusicAngel JH-MD04E2 wired speakers Disassembly, Board overview: step 5, image 1 of 1
    • Not really much going on on this board.
2 other people completed this guide.
Geir Ove Andersen
7,815 Reputation
5 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 240
