MyFirst Camera Insta 2 teardown
  1. MyFirst Camera Insta 2 teardown, Prepare teardown: step 1, image 1 of 3 MyFirst Camera Insta 2 teardown, Prepare teardown: step 1, image 2 of 3 MyFirst Camera Insta 2 teardown, Prepare teardown: step 1, image 3 of 3
    • Remove SD card, carry strap and paper cartridge
  2. MyFirst Camera Insta 2 teardown, Lift the front panel: step 2, image 1 of 2 MyFirst Camera Insta 2 teardown, Lift the front panel: step 2, image 2 of 2
    • Remove the front panel
    • The panel is simply clipped and can be declipped easily by using a mediator as lever
  3. MyFirst Camera Insta 2 teardown, Unscrew front panel: step 3, image 1 of 2 MyFirst Camera Insta 2 teardown, Unscrew front panel: step 3, image 2 of 2
    • The toy is closed by 5 Philips-head screws, size 0
    • Unscrew them all and open the product
  4. MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: step 4, image 1 of 3 MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: step 4, image 2 of 3 MyFirst Camera Insta 2 teardown, Remove the cartridge-holding piece: step 4, image 3 of 3
    • The white piece is held by 4 Philips-head screws
    • Unscrew the three screws you can already access
    • Unscrew the selfie camera, held by two smaller screws
    • Under the camera, unscrew the forth screw holding the piece
  5. MyFirst Camera Insta 2 teardown, Disconnect the screen: step 5, image 1 of 1
    • Remove the glue around the screen connector
    • Disconnect by lifting the connector clip upward
  6. MyFirst Camera Insta 2 teardown, Unscrew the PCB: step 6, image 1 of 2 MyFirst Camera Insta 2 teardown, Unscrew the PCB: step 6, image 2 of 2
    • The board is held by the 4 previously removed screws, plus another screw close to USB connector
    • Once all those are removed and the screen is disconnected, pull the card from its compartment by sliding it on the side opposite to USB connector
  7. MyFirst Camera Insta 2 teardown, Teardown view: step 7, image 1 of 3 MyFirst Camera Insta 2 teardown, Teardown view: step 7, image 2 of 3 MyFirst Camera Insta 2 teardown, Teardown view: step 7, image 3 of 3
    • Unknown microcontrolleur, QFP80 package , with reference "2104G-91"
    • Princeton Technology PT5139-HT motor driver
    • Syncrown PT48D 2-inch thermal printer
    • Thinksum 123050 7.4V 750mAh li-ion battery
    • Screen, speaker, two photo modules
To reassemble your device, follow the unmounting instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Eve Redero
3,138 Reputation
10 Guides authored
1 Guide Comment
Hi,
Where can I purchase a replacement lcd screen for the “myfirst camera insta 2” model no. FC2401
Christian Juul Henriksen - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 56
All Time: 719
