N-Strike Nite Finder EX-3 Battery Replacement
  1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: step 1, image 1 of 1
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. N-Strike Nite Finder EX-3 Battery Replacement: step 2, image 1 of 1
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
Nicholas Samokyszyn
359 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,752
