N-Strike Nite Finder EX-3 Trigger Replacement
  1. N-Strike Nite Finder EX-3 Trigger Replacement, Trigger: step 1, image 1 of 1
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Trigger Replacement: step 2, image 1 of 3 N-Strike Nite Finder EX-3 Trigger Replacement: step 2, image 2 of 3 N-Strike Nite Finder EX-3 Trigger Replacement: step 2, image 3 of 3
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. N-Strike Nite Finder EX-3 Trigger Replacement: step 3, image 1 of 2 N-Strike Nite Finder EX-3 Trigger Replacement: step 3, image 2 of 2
    • Remove the phillips head, 10.2 mm screw holding the trigger in place.
  4. N-Strike Nite Finder EX-3 Trigger Replacement: step 4, image 1 of 1
    • Remove the trigger by pulling the piece straight up.
    • Caution: Do not let the spring fly off the spring
Kyle Schober
640 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,890
