NABI XD Charging port Replacement
  1. NABI XD Charging port Replacement, Rear panel: step 1, image 1 of 2 NABI XD Charging port Replacement, Rear panel: step 1, image 2 of 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Charging port Replacement: step 2, image 1 of 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Charging port Replacement, Battery: step 3, image 1 of 2 NABI XD Charging port Replacement, Battery: step 3, image 2 of 2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Charging port Replacement: step 4, image 1 of 1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Charging port Replacement, Charging port: step 5, image 1 of 2 NABI XD Charging port Replacement, Charging port: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Charging port Replacement: step 6, image 1 of 1
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
Marissa Schiereck
638 Reputation
6 Guides authored
USF Tampa, Team 17-2, Blackwell Fall 2016 Member of USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 574
