NETGEAR WGT624 v3 Lower Case Replacement
  1. NETGEAR WGT624 v3 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Lower Case Replacement: step 2, image 1 of 3 NETGEAR WGT624 v3 Lower Case Replacement: step 2, image 2 of 3 NETGEAR WGT624 v3 Lower Case Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Lower Case Replacement: step 3, image 1 of 2 NETGEAR WGT624 v3 Lower Case Replacement: step 3, image 2 of 2
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Lower Case Replacement: step 4, image 1 of 2 NETGEAR WGT624 v3 Lower Case Replacement: step 4, image 2 of 2
    • Lift the lower case straight up from the rest of the router.
Nicole Slagle
83 Reputation
2 Guides authored
Cal Poly, Team 3-31, Amido Winter 2013 Member of Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 468
