Introduction
This guide will show you how to replace the key caps on an NPET K10V3 keyboard. Over time, key caps can become worn, damaged, or clogged with debris. Removing a faulty key cap is a quick and easy process that requires little to no tools. Each key cap has a sleeve that connects into a housing to allow for proper contact of the membrane's corresponding pressure switches which sends the electric signal to the computer.
Special Requirements:
- Use a key cap remover if too tight for hands. (optional)
Hazards:
- Getting shocked if keyboard is not unplugged.
2 other people completed this guide.
