NVIDIA GeForce GTX 970 GPU Replacement
  1. NVIDIA GeForce GTX 970 GPU Replacement, GPU: step 1, image 1 of 2 NVIDIA GeForce GTX 970 GPU Replacement, GPU: step 1, image 2 of 2
    • Unplug all the external cables from the computer and ensure that the power supply is switched off.
  2. NVIDIA GeForce GTX 970 GPU Replacement: step 2, image 1 of 2 NVIDIA GeForce GTX 970 GPU Replacement: step 2, image 2 of 2
    • Remove the case side panel by applying pressure to the side and sliding the side panel toward the back of the case.
    • Some cases may have screws that must be removed or tabs that must be pressed before the siding will slide off.
  3. NVIDIA GeForce GTX 970 GPU Replacement: step 3, image 1 of 3 NVIDIA GeForce GTX 970 GPU Replacement: step 3, image 2 of 3 NVIDIA GeForce GTX 970 GPU Replacement: step 3, image 3 of 3
    • Pinch the lock at the end of the GPU power cable and carefully disconnect it.
  4. NVIDIA GeForce GTX 970 GPU Replacement: step 4, image 1 of 3 NVIDIA GeForce GTX 970 GPU Replacement: step 4, image 2 of 3 NVIDIA GeForce GTX 970 GPU Replacement: step 4, image 3 of 3
    • Remove the two Philips #1 mounting screws that attach the GPU to the inside of the case.
  5. NVIDIA GeForce GTX 970 GPU Replacement: step 5, image 1 of 3 NVIDIA GeForce GTX 970 GPU Replacement: step 5, image 2 of 3 NVIDIA GeForce GTX 970 GPU Replacement: step 5, image 3 of 3
    • Press down the locking tab at the base of the GPU.
  6. NVIDIA GeForce GTX 970 GPU Replacement: step 6, image 1 of 1
    • Remove the GPU from the case. If it does not move, check to make sure that steps 3-5 were properly performed.
  7. NVIDIA GeForce GTX 970 GPU Replacement: step 7, image 1 of 2 NVIDIA GeForce GTX 970 GPU Replacement: step 7, image 2 of 2
    • When inserting a replacement GPU, ensure that the base is lined up properly with the appropriate slot on the motherboard.
    • Once the replacement GPU is lined up, press down until you hear a click or can see that the locking tab is flipped up again.
To finish reassembly, follow steps 2-4 in reverse order.
11 other people completed this guide.
Nicholas Eichman
415 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 72
All Time: 7,505
