Nabi 2 Screen Replacement
  1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: step 1, image 1 of 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: step 1, image 2 of 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: step 1, image 3 of 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2  Screen Replacement: step 2, image 1 of 2 Nabi 2  Screen Replacement: step 2, image 2 of 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2  Screen Replacement: step 3, image 1 of 3 Nabi 2  Screen Replacement: step 3, image 2 of 3 Nabi 2  Screen Replacement: step 3, image 3 of 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2  Screen Replacement, Screen: step 4, image 1 of 3 Nabi 2  Screen Replacement, Screen: step 4, image 2 of 3 Nabi 2  Screen Replacement, Screen: step 4, image 3 of 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2  Screen Replacement: step 5, image 1 of 3 Nabi 2  Screen Replacement: step 5, image 2 of 3 Nabi 2  Screen Replacement: step 5, image 3 of 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
7 other people completed this guide.
Michelle
875 Reputation
4 Guides authored
USF Tampa, Team 4-3, Lacy Spring 2016 Member of USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Members
14 Guides authored
4 Guide Comments
Simple steps but very practical
myjamro - Reply
Is the LCD glued to the front glass/digitizer?
Brent Huff - Reply
It Worked Thank U So Much!!!
Sharon Thrash - Reply
a piece that holds the screen ribbon cable in broke off my nabis motherboard while taking the screen off. I eventually did get the screen back on.
NabiGuy - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 41
All Time: 8,192
