Introduction
This guide will demonstrate how to remove and replace your Nabi 2's battery. The battery powers your device, and over time your battery may lose its ability to function correctly. There are many reasons to perform this repair, but the most common causes are the device not turning on, and the device not holding a charge. This repair involves the use of a soldering iron; be very careful not to touch the hot end of the iron while it is plugged in. It is recommended to document the order of the battery wires before you detach them so that you can attach the new battery's wires in the correct order.
4 other people completed this guide.
3 Guide Comments
Was hoping you could provide the replacement part number for this battery.
It shows on the picture: 1ICP6/68/112
Zoltan -
Hi,
where i can buy this replacement battery?
Thanks
