Nabi 2 Headphone Jack Replacement
  1. Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: step 1, image 1 of 3 Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: step 1, image 2 of 3 Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: step 1, image 3 of 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Headphone Jack Replacement: step 2, image 1 of 2 Nabi 2 Headphone Jack Replacement: step 2, image 2 of 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Headphone Jack Replacement: step 3, image 1 of 3 Nabi 2 Headphone Jack Replacement: step 3, image 2 of 3 Nabi 2 Headphone Jack Replacement: step 3, image 3 of 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Headphone Jack Replacement, Screen: step 4, image 1 of 3 Nabi 2 Headphone Jack Replacement, Screen: step 4, image 2 of 3 Nabi 2 Headphone Jack Replacement, Screen: step 4, image 3 of 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2 Headphone Jack Replacement: step 5, image 1 of 3 Nabi 2 Headphone Jack Replacement: step 5, image 2 of 3 Nabi 2 Headphone Jack Replacement: step 5, image 3 of 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
  6. Nabi 2 Headphone Jack Replacement, Battery: step 6, image 1 of 3 Nabi 2 Headphone Jack Replacement, Battery: step 6, image 2 of 3 Nabi 2 Headphone Jack Replacement, Battery: step 6, image 3 of 3
    • Use the spudger to pop the battery out of place and set it aside.
  7. Nabi 2 Headphone Jack Replacement: step 7, image 1 of 3 Nabi 2 Headphone Jack Replacement: step 7, image 2 of 3 Nabi 2 Headphone Jack Replacement: step 7, image 3 of 3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
  8. Nabi 2 Headphone Jack Replacement, Internal Speakers: step 8, image 1 of 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  9. Nabi 2 Headphone Jack Replacement: step 9, image 1 of 3 Nabi 2 Headphone Jack Replacement: step 9, image 2 of 3 Nabi 2 Headphone Jack Replacement: step 9, image 3 of 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  10. Nabi 2 Headphone Jack Replacement: step 10, image 1 of 1
    • Once the screws have been removed, remove the speakers from the device.
  11. Nabi 2 Headphone Jack Replacement, Motherboard: step 11, image 1 of 2 Nabi 2 Headphone Jack Replacement, Motherboard: step 11, image 2 of 2
    • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
  12. Nabi 2 Headphone Jack Replacement: step 12, image 1 of 3 Nabi 2 Headphone Jack Replacement: step 12, image 2 of 3 Nabi 2 Headphone Jack Replacement: step 12, image 3 of 3
    • Remove the tape that is attaching the motherboard to the plastic casing
  13. Nabi 2 Headphone Jack Replacement: step 13, image 1 of 3 Nabi 2 Headphone Jack Replacement: step 13, image 2 of 3 Nabi 2 Headphone Jack Replacement: step 13, image 3 of 3
    • Remove the motherboard by lifting from the area indicated
  14. Nabi 2 Headphone Jack Replacement, Headphone Jack: step 14, image 1 of 3 Nabi 2 Headphone Jack Replacement, Headphone Jack: step 14, image 2 of 3 Nabi 2 Headphone Jack Replacement, Headphone Jack: step 14, image 3 of 3
    • Desolder the six pins attaching the headphone jack to the motherboard
    • Remove headphone jack from motherboard
Amy
285 Reputation
2 Guides authored
USF Tampa, Team 4-3, Lacy Spring 2016 Member of USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 1,289
