Nabi 2 Heat Sink Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Nabi 2 Heat Sink Replacement, Open the device: step 1, image 1 of 1
    • Remove all the screws and place them on a magnet. This will keep them from rolling away and becoming lost.
  2. Nabi 2 Heat Sink Replacement: step 2, image 1 of 1
    • Insert a flat-edge and attempt to gently pry the covers apart. If you pry them too roughly, they may crack and break. (DO NOT have a magnet near the tablet when you open it. This will destroy all files and programs on your tablet, making it useless.)
  3. Nabi 2 Heat Sink Replacement, Look for Heat Sink: step 3, image 1 of 1
    • Check to see if there is a large piece of metal tape over the battery. This is the heat sink. Its purpose is to disburse the heat away from the battery and hard drive, cooling the tablet and keeping it from overheating.
    • If the piece of tape is not there, and the tablet will not turn on, the tablet most likely shorted out.
    • If the piece of tape is missing, you will need to purchase the appropriate metal tape. This can be found online.
5 other people completed this guide.
lauryn
215 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,296
