Nabi 2 Internal Speakers Replacement
  1. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: step 1, image 1 of 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: step 1, image 2 of 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: step 1, image 3 of 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Internal Speakers Replacement: step 2, image 1 of 2 Nabi 2 Internal Speakers Replacement: step 2, image 2 of 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Internal Speakers Replacement: step 3, image 1 of 3 Nabi 2 Internal Speakers Replacement: step 3, image 2 of 3 Nabi 2 Internal Speakers Replacement: step 3, image 3 of 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Internal Speakers Replacement, Internal Speakers: step 4, image 1 of 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  5. Nabi 2 Internal Speakers Replacement: step 5, image 1 of 3 Nabi 2 Internal Speakers Replacement: step 5, image 2 of 3 Nabi 2 Internal Speakers Replacement: step 5, image 3 of 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  6. Nabi 2 Internal Speakers Replacement: step 6, image 1 of 1
    • Once the screws have been removed, remove the speakers from the device.
Michelle
851 Reputation
4 Guides authored
USF Tampa, Team 4-3, Lacy Spring 2016 Member of USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 764
