Nabi 2S Battery Replacement
  1. Nabi 2S Battery Replacement, Nabi 2S Disassembly: step 1, image 1 of 1
    • Remove the red rubber case from the device.
  2. Nabi 2S Battery Replacement: step 2, image 1 of 2 Nabi 2S Battery Replacement: step 2, image 2 of 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Battery Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Battery Replacement: step 4, image 1 of 1
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Battery Replacement, Battery: step 5, image 1 of 3 Nabi 2S Battery Replacement, Battery: step 5, image 2 of 3 Nabi 2S Battery Replacement, Battery: step 5, image 3 of 3
    • Grasp the circuit connected to the battery via wires.
    • Slide the wires from the circuit to detach it.
  6. Nabi 2S Battery Replacement: step 6, image 1 of 2 Nabi 2S Battery Replacement: step 6, image 2 of 2
    • After the circuit is detached, the battery will be easily removable.
    • Don’t rip the battery off of the board.
    • The battery is stuck with adhesive tape to the board.
    • Use a plastic opening tool to apply pressure to the battery and lift it up from the adhesive.
4 other people completed this guide.
Riana Ramirez
680 Reputation
4 Guides authored
Marist, Team 1-4, Laflen Spring 2016 Member of Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 793
