Nabi Jr Camera Replacement
  1. Nabi Jr Camera Replacement, Rear Case: step 1, image 1 of 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Camera Replacement: step 2, image 1 of 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Camera Replacement: step 3, image 1 of 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Camera Replacement: step 4, image 1 of 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Camera Replacement, Camera: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers remove tape that connects the board to the camera's ribbon cable.
    • The ribbon cable is inserted into a slot on the board.
    • Lift the slot's locking tab up to easily remove the ribbon cable from the board.
    • May require force
  6. Nabi Jr Camera Replacement: step 6, image 1 of 1
    • Place the new camera piece in place of the old and plug its ribbon cable back into the respective slot on the board.
    • Make sure the locking tab on the slot is in its up position before inserting tape.
    • Once the tape is inserted press the locking tab back to its down position to securely fasten the ribbon cable.
Kaila Joy
86 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 372
