Navi Falk Neo550 Battery Replacement
Using a PH 0 screwdriver, loosen the four screws on the underside of the device.
Pull the plastic card at the lower corners, starting at the bottom of the screen.
At one of the bottom corners, remove the edge cover by sliding a plastic card from the front of the navigation system under the edge.
The edge strip is attached with double-sided tape, the plastic card can be pushed with a sawing movement gradually under the side cover
Use the screwdriver PH 0 to remove the two screws at the upper edge.
Pull a plastic card between the wall and the side panel to separate them. After the sides also separate the upper edge.
Pull out the inner edge cover between the screen and the rear panel.
Pull the battery cable downwards, then out from the guide nose.
Remove the adhesive tape from the battery.
Pull plug out of socket.
Install new battery. Reassemble the unit in reverse order of disassembly steps.
For me, the device worked well after the battery replacement. It was easy to turn on and off.
Meanwhile, there was occasionally "freezing" the display while navigating, which could be remedied with a reboot. Maybe a hardware defect, which also affects the charging function. The new battery enough for about 2 hours navigation without charging cable too little, I think.
Works permanently well. Also battery charge has gotten better. Maybe it was because the battery was too new.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
