Navi Falk Neo550 Battery Replacement
John Maier
John Maier and 2 other contributors
Last updated on February 2, 2021
No estimate
Moderate
Community-Contributed Guide
  1. Navi Falk Neo550 Battery Replacement, Unscrew lower edge cover: step 1, image 1 of 3 Navi Falk Neo550 Battery Replacement, Unscrew lower edge cover: step 1, image 2 of 3 Navi Falk Neo550 Battery Replacement, Unscrew lower edge cover: step 1, image 3 of 3
    • Using a PH 0 screwdriver, loosen the four screws on the underside of the device.
  2. Navi Falk Neo550 Battery Replacement, Release the screen: step 2, image 1 of 3 Navi Falk Neo550 Battery Replacement, Release the screen: step 2, image 2 of 3 Navi Falk Neo550 Battery Replacement, Release the screen: step 2, image 3 of 3
    • Pull the plastic card at the lower corners, starting at the bottom of the screen.
  3. Navi Falk Neo550 Battery Replacement, Remove the edge cover: step 3, image 1 of 3 Navi Falk Neo550 Battery Replacement, Remove the edge cover: step 3, image 2 of 3 Navi Falk Neo550 Battery Replacement, Remove the edge cover: step 3, image 3 of 3
    • At one of the bottom corners, remove the edge cover by sliding a plastic card from the front of the navigation system under the edge.
    • The edge strip is attached with double-sided tape, the plastic card can be pushed with a sawing movement gradually under the side cover
    • Caution: At the two lower corners, the cover strip is inserted into the housing with a latching lug.
  4. Navi Falk Neo550 Battery Replacement, remove inner edge cover: step 4, image 1 of 2 Navi Falk Neo550 Battery Replacement, remove inner edge cover: step 4, image 2 of 2
    • Use the screwdriver PH 0 to remove the two screws at the upper edge.
  5. Navi Falk Neo550 Battery Replacement, Separate wall: step 5, image 1 of 2 Navi Falk Neo550 Battery Replacement, Separate wall: step 5, image 2 of 2
    • Pull a plastic card between the wall and the side panel to separate them. After the sides also separate the upper edge.
  6. Navi Falk Neo550 Battery Replacement, remove inner edge cover: step 6, image 1 of 1
    • Pull out the inner edge cover between the screen and the rear panel.
  7. Navi Falk Neo550 Battery Replacement, Disconnect the battery cable: step 7, image 1 of 2 Navi Falk Neo550 Battery Replacement, Disconnect the battery cable: step 7, image 2 of 2
    • Pull the battery cable downwards, then out from the guide nose.
  8. Navi Falk Neo550 Battery Replacement, Disconnect the battery cable: step 8, image 1 of 1
    • Remove the adhesive tape from the battery.
    • Pull plug out of socket.
  9. Navi Falk Neo550 Battery Replacement: step 9, image 1 of 3 Navi Falk Neo550 Battery Replacement: step 9, image 2 of 3 Navi Falk Neo550 Battery Replacement: step 9, image 3 of 3
    • The battery is glued to the housing with a very tough adhesive tape. "Carefully" pry out. (You can probably solve this with isopropyl alcohol - I read later).
    • Install new battery. Reassemble the unit in reverse order of disassembly steps.
    • For me, the device worked well after the battery replacement. It was easy to turn on and off.
    • Meanwhile, there was occasionally "freezing" the display while navigating, which could be remedied with a reboot. Maybe a hardware defect, which also affects the charging function. The new battery enough for about 2 hours navigation without charging cable too little, I think.
    • Works permanently well. Also battery charge has gotten better. Maybe it was because the battery was too new.
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
John Maier
1,360 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 15
All Time: 1,481
