Neato BOTVAC CONNECTED Battery Replacement
  1. Neato BOTVAC CONNECTED Battery Replacement, Battery: step 1, image 1 of 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Battery Replacement: step 2, image 1 of 2 Neato BOTVAC CONNECTED Battery Replacement: step 2, image 2 of 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Battery Replacement: step 3, image 1 of 2 Neato BOTVAC CONNECTED Battery Replacement: step 3, image 2 of 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Battery Replacement: step 4, image 1 of 3 Neato BOTVAC CONNECTED Battery Replacement: step 4, image 2 of 3 Neato BOTVAC CONNECTED Battery Replacement: step 4, image 3 of 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Battery Replacement: step 5, image 1 of 1
    • Using the spudger, gently remove the battery from the device.
Justin Silva
645 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 37
All Time: 427
