Neato BOTVAC CONNECTED Filter Replacement
Justin Silva
Justin Silva and 3 other contributors
Last updated on May 12, 2023
5 minutes
Moderate
Introduction
Go to step 1
In this guide you will be able to replace the filter of the Neato Botvac Connected. The filter will need to be changed or cleaned once too much debris has built up causing the vacuum to no longer pick up dirt. The filter of the vacuum should be changed every few months to ensure the Neato Botvac is picking up debris properly. Following this guide comes after first following the guide to replace the battery to ensure safety.
Tools
  1. Neato BOTVAC CONNECTED Filter Replacement, Battery: step 1, image 1 of 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Filter Replacement: step 2, image 1 of 2 Neato BOTVAC CONNECTED Filter Replacement: step 2, image 2 of 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Filter Replacement: step 3, image 1 of 2 Neato BOTVAC CONNECTED Filter Replacement: step 3, image 2 of 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Filter Replacement: step 4, image 1 of 3 Neato BOTVAC CONNECTED Filter Replacement: step 4, image 2 of 3 Neato BOTVAC CONNECTED Filter Replacement: step 4, image 3 of 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Filter Replacement: step 5, image 1 of 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Filter Replacement, Filter: step 6, image 1 of 1
    • Flip the cleaner around and locate the front panel.
  7. Neato BOTVAC CONNECTED Filter Replacement: step 7, image 1 of 1
    • Gently remove the front panel by opening it with a spudger.
  8. Neato BOTVAC CONNECTED Filter Replacement: step 8, image 1 of 2 Neato BOTVAC CONNECTED Filter Replacement: step 8, image 2 of 2
    • Use the spudger to gently remove the paper filter.
Justin Silva
645 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 91
