Neato BOTVAC D5 Main Roller Brush Replacement
  1. Neato BOTVAC D5 Main Roller Brush Replacement, Side Brush: step 1, image 1 of 1
    • Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
  2. Neato BOTVAC D5 Main Roller Brush Replacement: step 2, image 1 of 2 Neato BOTVAC D5 Main Roller Brush Replacement: step 2, image 2 of 2
    • Firmly grasp and pull on the side brush and it will pop right off
  3. Neato BOTVAC D5 Main Roller Brush Replacement, Main Roller Brush: step 3, image 1 of 2 Neato BOTVAC D5 Main Roller Brush Replacement, Main Roller Brush: step 3, image 2 of 2
    • Pop the tabs shown on the main brush cover, and then pull. It should come right off. You can put it aside for now.
  4. Neato BOTVAC D5 Main Roller Brush Replacement: step 4, image 1 of 2 Neato BOTVAC D5 Main Roller Brush Replacement: step 4, image 2 of 2
    • The Main brush will pop right out when you attempt to remove it.
    • When replacing the main brush make sure to orient it correctly.
Laurent Kwan
337 Reputation
3 Guides authored
UMass Dartmouth, Team 3-3, Konn Fall 2023 Member of UMass Dartmouth, Team 3-3, Konn Fall 2023
UMASSD-KONN-F23S3G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 136
