Neato Botvac 65 Top Cover Removal
  1. Neato Botvac 65 Top Cover Removal, Battery: step 1, image 1 of 2 Neato Botvac 65 Top Cover Removal, Battery: step 1, image 2 of 2
    • Flip the device upside down.
    • Locate the two (2) 20mm screws on the batttery plate.
  2. Neato Botvac 65 Top Cover Removal: step 2, image 1 of 2 Neato Botvac 65 Top Cover Removal: step 2, image 2 of 2
    • Use the Phillips #1 screwdriver to loosen both screws.
  3. Neato Botvac 65 Top Cover Removal: step 3, image 1 of 1
    • Remove the battery back plate to reveal the battery.
  4. Neato Botvac 65 Top Cover Removal: step 4, image 1 of 2 Neato Botvac 65 Top Cover Removal: step 4, image 2 of 2
    • Disconnect the current battery by pulling the connector from the base and pushing on the clip.
  5. Neato Botvac 65 Top Cover Removal, Brush: step 5, image 1 of 1
  6. Neato Botvac 65 Top Cover Removal: step 6, image 1 of 2 Neato Botvac 65 Top Cover Removal: step 6, image 2 of 2
    • Use the screwdriver to take off the four (4) 10mm screws located near the brush which secure the plastic guard.
  7. Neato Botvac 65 Top Cover Removal: step 7, image 1 of 2 Neato Botvac 65 Top Cover Removal: step 7, image 2 of 2
    • Remove the plastic brush guard.
    • Pull off the plastic covering the brush.
  8. Neato Botvac 65 Top Cover Removal: step 8, image 1 of 1
    • Lift the brush to clean or replace.
  9. Neato Botvac 65 Top Cover Removal, Top Cover: step 9, image 1 of 1
    • Flip device upside down.
    • Locate the six (6) screw connected to the top cover.
  10. Neato Botvac 65 Top Cover Removal: step 10, image 1 of 1
    • Remove eight (8) star screws using the T10 bit.
  11. Neato Botvac 65 Top Cover Removal: step 11, image 1 of 2 Neato Botvac 65 Top Cover Removal: step 11, image 2 of 2
    • Pull off one side of the brush front cover, and then pull off the other.
  12. Neato Botvac 65 Top Cover Removal: step 12, image 1 of 1
    • Flip right side up and turn around.
    • FInd the two clips connecting the top cover to the body of the device.
  13. Neato Botvac 65 Top Cover Removal: step 13, image 1 of 2 Neato Botvac 65 Top Cover Removal: step 13, image 2 of 2
    • Lift up on the top cover gently.
    • Disconnect the connector from the motherboard to detach the top cover from the robot.
Joseph Caton
334 Reputation
3 Guides authored
USF Tampa, Team S2-G1, Lacy Spring 2017 Member of USF Tampa, Team S2-G1, Lacy Spring 2017
USFT-LACY-S17S2G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,298
