Neato Botvac 65 Wheel Motors Replacement
  1. Neato Botvac 65 Wheel Motors Replacement, Battery: step 1, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement, Battery: step 1, image 2 of 2
    • Flip the device upside down.
    • Locate the two (2) 20mm screws on the batttery plate.
  2. Neato Botvac 65 Wheel Motors Replacement: step 2, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 2, image 2 of 2
    • Use the Phillips #1 screwdriver to loosen both screws.
  3. Neato Botvac 65 Wheel Motors Replacement: step 3, image 1 of 1
    • Remove the battery back plate to reveal the battery.
  4. Neato Botvac 65 Wheel Motors Replacement: step 4, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 4, image 2 of 2
    • Disconnect the current battery by pulling the connector from the base and pushing on the clip.
  5. Neato Botvac 65 Wheel Motors Replacement, Brush: step 5, image 1 of 1
  6. Neato Botvac 65 Wheel Motors Replacement: step 6, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 6, image 2 of 2
    • Use the screwdriver to take off the four (4) 10mm screws located near the brush which secure the plastic guard.
  7. Neato Botvac 65 Wheel Motors Replacement: step 7, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 7, image 2 of 2
    • Remove the plastic brush guard.
    • Pull off the plastic covering the brush.
  8. Neato Botvac 65 Wheel Motors Replacement: step 8, image 1 of 1
    • Lift the brush to clean or replace.
  9. Neato Botvac 65 Wheel Motors Replacement, Top Cover: step 9, image 1 of 1
    • Flip device upside down.
    • Locate the six (6) screw connected to the top cover.
  10. Neato Botvac 65 Wheel Motors Replacement: step 10, image 1 of 1
    • Remove eight (8) star screws using the T10 bit.
  11. Neato Botvac 65 Wheel Motors Replacement: step 11, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 11, image 2 of 2
    • Pull off one side of the brush front cover, and then pull off the other.
  12. Neato Botvac 65 Wheel Motors Replacement: step 12, image 1 of 1
    • Flip right side up and turn around.
    • FInd the two clips connecting the top cover to the body of the device.
  13. Neato Botvac 65 Wheel Motors Replacement: step 13, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 13, image 2 of 2
    • Lift up on the top cover gently.
    • Disconnect the connector from the motherboard to detach the top cover from the robot.
  14. Neato Botvac 65 Wheel Motors Replacement, Wheel Motors: step 14, image 1 of 3 Neato Botvac 65 Wheel Motors Replacement, Wheel Motors: step 14, image 2 of 3 Neato Botvac 65 Wheel Motors Replacement, Wheel Motors: step 14, image 3 of 3
    • Remove four (4) 10mm 'star' screws using the T10 bit from the base plate where the rotating infrared sensor is located.
    • Carefully place the sensor on or near the robot without pulling the wires out.
  15. Neato Botvac 65 Wheel Motors Replacement: step 15, image 1 of 1
    • Remove two (2) screws using the T10 bit that connects the plastic protector over the wheel motor.
    • Pull up on the metal weight to remove.
  16. Neato Botvac 65 Wheel Motors Replacement: step 16, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 16, image 2 of 2
    • Flip the botvac over being careful not to drop the IR sensor or cause damage to the wires.
    • Using a flat-head screw driver and a cloth for protection, press on the clips until they recede into the botvac.
  17. Neato Botvac 65 Wheel Motors Replacement: step 17, image 1 of 2 Neato Botvac 65 Wheel Motors Replacement: step 17, image 2 of 2
    • Flip the robot back over(right-side up).
    • Carefully remove the plastic cover that protects the motor.
  18. Neato Botvac 65 Wheel Motors Replacement: step 18, image 1 of 3 Neato Botvac 65 Wheel Motors Replacement: step 18, image 2 of 3 Neato Botvac 65 Wheel Motors Replacement: step 18, image 3 of 3
    • Carefully remove the motor that you wish to replace.
    • Trace the wires that are connected to the motor back to the motherboard.
    • Disconnect the connector from the motherboard for the respective motor you're replacing.
Joseph Caton
334 Reputation
3 Guides authored
USF Tampa, Team S2-G1, Lacy Spring 2017 Member of USF Tampa, Team S2-G1, Lacy Spring 2017
USFT-LACY-S17S2G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,477
