Neato Botvac 80 Battery Replacement
  1. Neato Botvac 80 Battery Replacement, Loosening screws: step 1, image 1 of 3 Neato Botvac 80 Battery Replacement, Loosening screws: step 1, image 2 of 3 Neato Botvac 80 Battery Replacement, Loosening screws: step 1, image 3 of 3
    • First, open the bin compartment and flip the switch to the off position.
    • Once you have done this, flip the robot over. Loosen the 2 screws, and lift the flap off
    • You will need to remove the 22.5mm bolts with a J1 Torx screwdriver.
    • Screws cannot be removed from the cover.
  2. Neato Botvac 80 Battery Replacement, Remove battery cover: step 2, image 1 of 2 Neato Botvac 80 Battery Replacement, Remove battery cover: step 2, image 2 of 2
    • Gently lift to remove battery cover.
  3. Neato Botvac 80 Battery Replacement, Removing battery: step 3, image 1 of 3 Neato Botvac 80 Battery Replacement, Removing battery: step 3, image 2 of 3 Neato Botvac 80 Battery Replacement, Removing battery: step 3, image 3 of 3
    • Locate battery clip.
    • Press down on latch with thumb and slide clip back.
    • Remove the battery.
Alexander Silfa
300 Reputation
1 Guide authored
USF Tampa, Team 17-5, Blackwell Spring 2017 Member of USF Tampa, Team 17-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G5
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 25
All Time: 5,030
