Neato XV Signature Wheel Assembly Replacement
  1. Neato XV Signature Wheel Assembly Replacement, Wheel Assembly: step 1, image 1 of 1
    • Place the Neato with the bottom side facing up.
  2. Neato XV Signature Wheel Assembly Replacement: step 2, image 1 of 1
    • Remove the four machine screws securing the main compartment plate using a Phillips #0 screwdriver.
  3. Neato XV Signature Wheel Assembly Replacement: step 3, image 1 of 2 Neato XV Signature Wheel Assembly Replacement: step 3, image 2 of 2
    • Remove the main compartment plate, exposing the wheel axis and fan.
  4. Neato XV Signature Wheel Assembly Replacement: step 4, image 1 of 1
    • Lift up on the wheel axis to remove the axle bar from its clasp.
  5. Neato XV Signature Wheel Assembly Replacement: step 5, image 1 of 2 Neato XV Signature Wheel Assembly Replacement: step 5, image 2 of 2
    • Remove the axle bar from the wheel mount, exposing the suspension spring.
  6. Neato XV Signature Wheel Assembly Replacement: step 6, image 1 of 2 Neato XV Signature Wheel Assembly Replacement: step 6, image 2 of 2
    • Unlatch the suspension spring from the wheel mount, exposing the wheel connector cable.
  7. Neato XV Signature Wheel Assembly Replacement: step 7, image 1 of 1
    • Unplug the wheel connector cable.
    • Repeat steps 4-7 with the other wheel.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 194
