Neato XV-21 Battery Replacement/Removal
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: step 1, image 1 of 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: step 2, image 1 of 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: step 3, image 1 of 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: step 4, image 1 of 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
3 other people completed this guide.
One Comment
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 1,194
